Message |
Ok folks, I have been working on this for a few hours and can't figure out what I'm doing wrong. I'm attempting to remove an aluminum 1 piece driveshaft from my parts car to eventually remove the entire drivetrain and rear subframe. I managed to get all 6 of those PITA hex bolts out, but the shaft still won't drop. I've separated the rear flange from the diff but I can't seem to pry it far enough to get it to drop out of that housing at the diff. I thought it was supposed to slide a little forward into the trans to give some space but no dice. Any ideas? I need probably another half inch.
